1994 Larson 190
Mercruiser Alpha 1
In troubleshooting my boat not trimming up. Tried bypassing trim limiter but no success, so I followed the female bullet connector leads from the trim harness. One splices to the trim switch wiring (RGB) but the other (pink to brown) was separated near the control arm. Where is this supposed to connect? I'm down to suspecting the trim won't go up because either the actual rocker switch is bad OR the open circuit related to the trim limiter is causing the issue.
Things I've done:
- Replaced sender/limit sensors
- Tested continuity of switch wires from control to terminal
- Tested both solenoids (good)
Any/all suggestions are appreciated!
Mercruiser Alpha 1
Things I've done:
