Testing a Mercruiser fuel pressure regulator
srdancer320
I have a 2004 350 MAG MIE SR om396072, I want to test the FPR, but I can not reach the vacuum hose that is attached to the FPR nipple(as it is burried under the motor mount between two engines.) Can I test to see if there is fuel in the line at the location where this hose enters the intake manifold,any help is appreciated.Joe
Failproof
Re: Testing a Mercruiser fuel pressure regulator
Yes, you can test downline. As long as nothing else is tee'd inline to affect the test
