This is going to sound confusing but i am going to give it my best...
I have a 1976 Johnson 135, I have had problems with the low speed ideal for some time. I talk to a mechanic and he told me at first to try a few things... 2 weeks and 800.00 later and the same problem
Here is what i have done:
-Clean and rebuilt carbs - mechanic also looked them over as to be in great shape. all intake gaskets are ok and tested.
-New fuel pump and all new hoses - primer ball is rock hard and fuel tank is good because is it also new.
-reeds are all tested and seat well - no problem there
-compression is great with 165 on one side and 155 on the other - me and the mechanic don't think the motor was ever used.
-New CDI box or Brain and 4 new coil packs and spark plugs. all coils and plugs are on the right cylinders firing in the right order.
-New gear fluid changed and topped off.
-Prop is in good shape and taken off to make sure there is no rope or wire restricting it.
With my ideal setting maxed out and in water the RPMs show 500 or 600, this is with the prop on. When i engage it into gear it will die every time motor worm or cold.
With the prop off it will ideal better and it will not die out when kicked into great.
The timing at the 500 and 600 RPM is below TDC so about -4. This motor does not have an ideal timing setting or that i can find online. There is the WOT which is set correct.
all the is left is the stator or anything under the flywheel.... also the device that converts AC to DC is reading 8...15...20...4...16... on the volt meter when it is running.
I know this is a lot and probable confusing to read bust i am not sure what is left to do or what direction i should waste more more money in hahahah.
any help would be great,
Jeremy
and new well mixed gas is used....
Jeremy
