Exhaust shuttle valve help 3 pc. pipe. merc
llerrad
74, merc three piece exhaust pipe V8, anyone got the secret to remove the three socket head cap screws without removing engine?<br />Special mod. wrench or point of access. one bolt tucked in behind bell housing.
Re: Exhaust shuttle valve help 3 pc. pipe. merc
Well,...... That's Usually done with the Engine Out........<br /><br />Getting it Out is going to be Tough......<br /><br />I'm Guessing,..... Putting it Back Together is Probably going to be Impossible.......
llerrad
ahhhh crap!!!!!!
Haut Medoc
Leave it out!....(Shutter) Don't kill the engine at full throttle & beach it!.....I would not sweat the fact that it fell of.....& I will guess that your performance has improved with it removed from your drive.....I would not worry about it until I had to remove the engine for other reasons.....JK
Bt Doctur
except for the fact its not located there .if your referrring to the "exaust flapper" it should be at the second junction
Haut Medoc
From previous post: His flapper broke & was lodged in the bell housing ;) .....JK
Boatwizard
Have you looked in the LU and took the exhaust boot off and looked in there? The usually get caught in the bellcrank area of the bell housing or the around the carrier.
llerrad
Took leg off found flapper in exhaust port of transom ring.
