Mercurey 90HP, 2001, Shock from Sparkplug wire
mikedelaney
Hi All, I tried to find this on the forum but no luck. Recently while working on my 2001 Mercury 90HP, i bumped the #1 spark plug wire and recieved a shock. I did not think this should happen. I touched the number 2 and number 3 and no shcok. I turned the engine off and check to make sure the pug was tight and the wires was full inserted and started it up. Same thing, a shock if you touch the number 1 wire. I assume this is not good and could be some of my other issues. Any ideas on how to fix or what is wrong? Thanks
Sunfish12
Re: Mercurey 90HP, 2001, Shock from Sparkplug wire
Swap wires, if it follows to another cylinder then it's just the wire. Replace.
