SoCalBayliner
- Jun 26, 2012
- 9
I recently purchased a 2004 Bayliner 175 with a 3.0 Mercruiser, the previous owner only ran the boat at Big Bear (~6700 ft above sea level) i took it to Lake Elsinore (~1300 ft) and it would not idle, I managed to get it out of the no wake zone and it ran fine at high RPM around the lake but when i backed off it would die. I thought it was re-jetted for high altitude but it does have the stock 1.55mm jets. I have read that the timing can be adjusted for high altitude operation, but would that keep it from idle down at 1300'? The previous owner had it tuned to run at high altitude but does not know what they did, i can get it to keep running by holding the choke closed with my hand but when i let it open the engine stalls, like it is not getting enough fuel at idle. Any sugestions on what to check would be much appreciated.
