Damage inc.
Part-time
This came into the shop this morning...
The guy hit a rock doing 40mph+ ... and not a scratch on the hull!
Maclin
Re: Damage inc.
Did they say how they recovered the bottom end? I bet that is a good story ;)
espeed09
Re: Damage inc.
Was there any damage to the transom? I wonder if the engine is still good?
Part-time
Re: Damage inc.
Apparently the motor was still running after the hit.
The transom and the hull are intact.
The two trim/tilt cylinders were the only thing holding the lower to the boat...
The boat will be back in the water tomorrow.
Part-time
Today's fail...
Today's fail...
The older fella brings in his daughter's little pink and white SeaRay jet boat.
"I think there's water in the gas... it won't run right anymore."
I open the engine bay and upon inspection I didn't find water in the gas but I did find this...
:facepalm:
FlaCowboy
Ensign
Re: Today's fail...
Re: Today's fail...
Why was he pulling his motor behind his truck at 40 mph for:confused: No wonder the boat did not have a scratch on it :D
MH Hawker
Re: Today's fail...
Re: Today's fail...
Some JB Weld will fix it right up.
Nandy
Re: Today's fail...
Re: Today's fail...
:facepalm:
and that is????
Part-time
Re: Today's fail...
Re: Today's fail...
and that is????
Sorry... I kind of forgot the non mechanic guys.
It's a fried voltage regulator and the reason why, look at the connections on the battery.
CaptainKickback
Re: Damage inc.
Takes a lickin and keeps on tickin...
Sea ya...
Nandy
Re: Today's fail...
Re: Today's fail...
Actually I do quite a bit of mechanic work, the picture does not make it clear if you just placed that box there, what it is, if the box is grounded then it touched the + in the battery and it fried, ect....
FastFission
Re: Today's fail...
Re: Today's fail...
red cable = +, take a closer look...
TimBobCom
Re: Today's fail...
Re: Today's fail...
Huh, I just killed the 90 Amp fuse on my starter, and my stereo's fuse when I did that. The lesson I learned is that you don't change a battery at the ramp when you have a boat full of bikini-clad coeds waiting on you to change the battery. End result was no bikinis on the boat that day.
greenbush future
Re: Damage inc.
That outdrive can be fixed!! just a bead of caulk and it's good as new!!
The standing joke around my buddys who do construction, that's nothing a bead of caulk cant fix!!
tomdinwv
Re: Damage inc.
Duct tape and a can of spray paint will have that outdrive looking new in no time.
CharlieB
Re: Today's fail...
Re: Today's fail...
LOL I can understand how easy it is to make that mistake!
