Johnnydeep
- Nov 8, 2004
- 13
I have a 1990 7.4 merc with a bravo 1 outdrive in a 2855 bayliner, freshwater cooled and fw cooled risers. My question is I noticed a rust spot on the port side of the intake manifold when I bought the boat last summer, not bieng my first bayliner I assumed that it was water dripping or puddling on the top of the manifold causing rust. I ran the thing in the driveway last weekend and while it was idling and warming up I happended to brush my hand across the vale cover on that side and I could feel a bit of heat, tracked it down and the rusty spot on the intake was hot, not bad at idle but to hot to leave a bare hand on for more than 2 or 3 seconds. I put the boat in the water and it dawned on me as we idled away from the dock that it has seemed to run rough for the first few minutes until I get it up on plane when I start out cold, and the light kinda went on in my head...I think I have a bad lifter on that cylinders exhaust side! Am I right on this? <br /> One other question for don or the other techs, I know the merc riser and elbow gaskets are not the best design, do I need to replace the FW part of the riser/exhaust manifolds too or do the hold up better than when they are exposed to salt water... I am going to do the risers here very soon and suppose i should just do the whole thing and replace all the hoses while I have the cooling system drained....just wondering if its necessary
