Hello Fellow Boaters:
I have a prop question: We bought a virtually new 2005 Stratos 170FS (16' Fish/Ski, basically a bass boat), with a 2005 Johnson 115 HP 2-stroke J115PLSOR, and the existing prop is a 14"x17P 176215 Johnson OEM.
The boat is fast enough for me, gets to 45mph quickly with 80% (~475 lb.) loading which is normal for us, and the engine reaches max revs of 5500rpm at WOT also very quickly.
I do not need the boat to go any faster. We use it mainly for putting around and pulling skiers / tubes / kneeboards and such.
I would like a spare prop and was thinking a 4-blade would be a good choice.
However, the only OMC 13-spline 4-blade props I can find are 12.5" x 19 Solas.
Wouldn't this prop allow the engine to reach max WOT revs even quicker? I'm thinking instead I'd want to load the engine a bit more without creating more speed if that's possible, which means at least a 14 x 19 4-blade, and preferable larger diameter. Not more pitch 'cause I don't want more speed.
So my question: Is my thinking correct, and if so, does anyone know where I might look for a larger diameter 19P prop for this engine? Solas makes them, but they all seem to be 15 spline for larger engines.
Sorry for such a long first post, and thanks.
