Fuelish Pleasure
- Jun 25, 2012
- 5
I have 2005 350 with Bravo drive (OW619043). Several weeks ago, I started having fuel problems. The motor died on the lake and wouldn't stay started. A "MerCruiser Certified Technician" told me it was the Fuel Pumps (high flow pump most likely). Come to find out it may have only been one gas tank empty and the other was a stuck anti-syphon valve (after spending $600 on new fuel pumps and THEN checking other stuff...). So replaced fuel pumps, replaced anti-syphon valves and ran fine for 3 weeks now. This past weekend the the boat wouldn't run at idle (I could get it started by running the throttle up and then quickly and gracefully hitting neutral and gear to get going). but the 2 beeps per minute warning continuely goes off - even after shutting off and restarting same way. Looking for Any ideas on what to check next. I am somewhat handy but not sure what else to check and don't want to put the boat in the shop for an undetermined amount of summer! Thanks in advance!
