Lake Hickory River Rat
- Jun 19, 2012
- 2
This one is difficult to describe. Boat will idle and run at slow speed, but when you try to go fast or kick in the four barrel she stalls. Noticed the inline clear fuel filter is almost empty when tying to increase speed. Replaced the engine fuel pump last year. The main problem is the 18 gallon aluminum fuel tank is under the removeable rear seat and I can remove the 6 screws and the sending unit. You can see the pickup tube and screen thru this 2.5" diameter hole, but when you remove the elbow to the pickup tube there is no way to get the tube out. Can't get my hand or a tool to reach from the sending unit hole.
Since I have an inline filter I added I'm seriously considering running a sharp wire of some sort thru the tube and poking holes and that screen at the bottom of the pickup tube. Boat is an 18', 1976 Dixe with A 260 Mercruiser
Any suggestions appreciated !
