Re: Burned out diode?
Should there not already be a fuse on the +12V side? I would trace the the wire back to the distribution panel, or the source. If it's not fused, it should be. No need to replace the diode with a fuse, just make sure you have a fuse and replace the diode. Since there are two diodes, you should be able to get the number off the other easily.
