Engine alarm still coming on
Mrfiberglass
Engine alarm comes on / engine runs fine at high speed / shut motor off and start alarm will come on / pump bulb up and start motor will run fine for a while but at low speed just idling alarm will sound have to keep shutting down motor and resetting Johnson 225 v6 carbs does not seem like overheat
Chris1956
Re: Engine alarm still coming on
Can you provide year and model number for that motor? Also can you make slear sentences, as I am not sure of the issue? What is start alarm? Is it check engine self test?
Mrfiberglass
Thanks for answering Chris I'll try to explain / I can run at high speed no problems - when ii come to a stop engine sometimes wants to stall and does. When i restart I restart the motor the alarm will start sounding. If I pump the fuel bulb hard the engine will run for a while after starting and no alarm but engine will run fine . If the alarm comes on I gun it and pull back on the throttle and thealarm goes off 1995 Johnson v6 carb oceanrunner 2 stroke
Mrfiberglass
I don't have the model number in front of me right now it is not a starting alarm it is the alarm coming on after starting again and if I gun it and pull back on the throttle the alarm shuts off
Chris1956
Describe the alarm. Beeps? How far apart? What is year of motor? Pre 1995 or newer? Can you see if the motor is overheating? Use hands to feel head. Hands can touch normal head for a few seconds. Overheating motor may have burned paint or other symptoms. When was water pump changed last? Thermostats?
Chris1956
Sorry, I saw the year after posting....
Mrfiberglass
There is no paint burned and I have felt the water exiting and is warm to cool and long continuous beep thermo no idea and impella or water pump replaced info thanks for helping I appreciate your time model J225TXE it's either ( O ) or (D) B. J225TXEOB. Long beeps
w2much
Check out my post regarding my alarm problem. Mine was a 1995 motor on a 1996 boat with the newer type system check tach and binnacle ect. My alarm comes on intermittently only at slow speeds. Been chasing the problem for a long time. You may care to use premix until you solve the issue. Do you have a system check tack with the oil, hot, check engine and low oil lights? If so my thread may help you.
hidef
Long continuous beep is over heat alarm. The two main causes is a water pump going bad or a bad thermostat. When running at speed the water pump develops enough pressure to open up the bypass valves even a weak water pump can do that but it might not have enough volume to cool the engine at idle. If you don't know when the water pump was replaced start there first if that fixes it you are good. If it doesn't then move on to the thermostats and change those out. After that you have the overheat sensors a faulty or sensitive sensor could give a false alarm. Use an infrared thermometer take the cylinder temps they should be around 140 - 160 degrees if the cylinders are hotter than that you have trouble. The heads will be warmer than the cylinder water jacket.
Mrfiberglass
Thank you it seems to make sense although they say some engines have a fuel restriction long beep alarm but will check that out thanks again
hidef
They can also have a long beep on fuel restriction however you are getting the warning horn at low speed / idle. If you have a fuel restriction I would think you would be having issues at speed as that engine likes to drink fuel.
Mrfiberglass
Yah you might be right it sounds reasonable thank you I'm going in that direction
