Good day
I have an older 1988 Mirage and am having the interior done in it. After removing the rear seat and starting to clean up under it I found an issue once I removed the small square fuel sender access cover.
I do not have any pictures but at the very rear of the floor before where it stops to enter the bilge there is a square cut back (3 sides open to the bilge) on top of the fuel tank for sender access. The expossed wood under the molded cockpit insert was sealed but the edge towards the front of the boat must have wore away causing water intrusion to rot the wood under the cockpit insert. The other 2 sides seem solid and not wet. Hopefully it has not spread too far forward.
I was thinking about doing a spot repair on that area of wood mind you I am unsure how far it has spread yet and it is on top of the fuel tank I suspect. I dig out some of it with my hand and it goes forward at least my hand length.
My plan is to do a few small hole core drills with maybe 1/8 to see if I can determine how far it has gone. Then using a thin rotary blade attempt to slice a larger square through the cockpit cover layer and seperate from the floor with minimal cut into the floor. Cut and remove the rot back to decent wood and add a new piece into the section. Glass resin the removed cover back down to the replaced section.
My question what is the best way to replace the piece structurely as I can not get under it do to the fuel tank and using cloth above would not allow the cockpit cover to replace level, can the new piece be adhered in somehow to the edges of the floor left in or reduce the new piece width and glass over top?
Thanks
Mat
Thanks
Mat
