Re: Reinstalling reverse lockout on 90hp Inline 6
With the lower unit in neutral, the flat side of the cam should be aligned directly with the front centre (12:00 o'clock). Once you have this, shift the LU into Forward as well as the boat controls and install the LU. Once you have the LU installed, check the prop for correct gear selection using finger pressure only on the prop:
Forward: Prop will turn (ratchet) CW but not turn CCW
Neutral: Prop will turn freely in either direction
Reverse: Prop will not turn in either direction except for a few degrees of gear mesh.
Here is the link again to the condensed version of the Clymer manual in case you did not get to it in time. The link is short lived, so download it soonest to your computer. See figure M14-53 for the cam as described above.
http://web.ebscohost.com/serrc/pdf?sid=de93db92-63c7-40cb-981a-0c3367b18056@sessionmgr11&vid=7&hid=9
Gerry
