Been lurking here for a while, lots of great info. First time working on an Alpha 1 outdrive with the intention of replacing the water hose (PO installed one a bit too long, kinked and chafing) but figured I'd do all the bellows, water pump and maybe gimbal bearing while I was in there.
Everything is going well but I'm stuck at the shift cable It's the new style with the nut on the aft side. I've got the cable unhooked from the engine and have pulled it through the transom with a wire behind it to help get it back in. I've got the bell housing on the bench now, and I've welded together a 9/16" deep socket and another shorter socket to make a shift cable removal tool. I can get a really good grip on the nut, but I cannot turn it.
Was looking for answers/confirmation to these questions:
1. This nut should turn counterclockwise, right?
2. It should rotate the whole outer cable
I haven't used an impact wrench yet and I haven't used any heat. Right now it's soaking in penetrating oil and I've scratched away the small amount of corrosion that was around it.
Any advice for next steps? Don't want to break anything.
Plan B. may be to leave the existing shift boot in place.. it looks almost new.
Thanks in advance for any thoughts --
Greg
Greg
