Overfilled the Oil Reservoir in my 2008 Mercury 90HP 2 Stroke - Help?
kashabowie
Hi, after getting a low oil warning on Fathers Day, I have now overfilled the reservoir. Oil has stopped dripping from the lower housing unit now. What should I do next?
Many thanks for the help!
achris
More fish than mountain goat
Re: Overfilled the Oil Reservoir in my 2008 Mercury 90HP 2 Stroke - Help?
If you must, siphon some out, or just use the boat and the oil level will go down...
Chris.......
BTW, Welcome to iBoats....
Texasmark
Like Chris said, use it. If your oil filler seal leaks, don't tilt your engine all the way up till you use it down about 1/3. Otherwise get a new seal.
Mark
