Re: Four Winns transom leak
I have a 93' Four Winns with a OMC motor and Cobra outdrive. (not the King Cobra) I am leaking somewhere around the transom. I have replaced both bellows and some other seals when I removed the drive assembly a few months back. I believe the leak is coming from where the unit mates to the fiberglass. By the manual it looks like I will need only 2 seals. The strip seal around the housing and an interior seal. Is this all I will need? The book doesn't give great specifics. Any info on this teardown will be appreciated. Thanks in advance.
Howdy,
If you have a leak at the transom, you need to identify where it's leaking by putting it in the water and use whatever means are necessary (mirrors, flashlight etc) to determine where it's coming from.
It it's the actual transom seal, that could also mean a rotten transom. That will not be pretty. In any case, if you have to replace that seal, (which is on the outside), you will need to remove the drive, engine and transom-mount (in that order)
Any boat that as old as yours should be carefully checked for water intrusion into the transom, stringers, engine mount blocks etc. If your transom is rotten, there's not much you can do except either replace the transom, or remove the engine drive etc and replace the boat.
I know this sounds extreme but if you have a rotten transom, you'll never be able to maintain engine/drive alignment which will eventually destroy your coupler (and strand you)
Which manual are you talking about?
I only remember one seal.
#65 below
I don't think there's an "inner" seal associated with the inner transom plate.
