OK so I have an 85 17' Chris Craft with a 85 (I believe) MerCruiser I/O 140 (serial 06920736) with alpha 1 outdrive.. here's the issue bought the boat 2 years ago took it out on the water it would run and idle great come up to plane fine and the speedometer would say 50-55mph top speed, but while going between idle to full throttle sometimes it would stall out and take a few times to fire back up (thought it was just the carb needed to be cleaned but didn't get around to it)... ok that was the beginning delt with it a few more trips everything was ok... Now present day the boat sat for lets say a year and a half (winterized of course) so did massive cleaning job bought new battery, then installed new spark plugs,new wires, new points, new starter, new fuel filter, rebuilt the carb to specs cleaned it well with gallon can carb cleaner (soaked all parts) and blew out with compressed air. started it in the driveway with muffs fired up after a 2 pumps on the throttle idled very well in the driveway when it felt like it sometimes the motor would shake the boat violently but would calm down, adjusted the idle screw then it ran fine at idle 500-600 rpms. took the boat out today took a few tries but started up and idled good in the water, then stalled when tried to put in gear... finally got it to run in gear after playing with the throttle a bit and adjusting the idle screw... so now I am idling through the no wake zone and its fine burning a little lean and sometimes violently shaking the boat but going.... now out of the no wake zone go to give throttle it stalls and backfires... play with the throttle and I can start to gain speed but it will not go above 2000 rpm even at full throttle and the boat will not gain any speed maybe a few mph over idle speed. the prop is a little dinged up but the same way it was when it would plane fine and get up to speed fine.
so after that novel my issue is that on the water with the prop spinning the boat will not gain any speed maybe a few mph over idle and not go above 2000 RPMs....
any ideas hopefully I can fix this and get back on the water next weekend....
