I have a 2000 50 Hp 2 stroke that I bought new. I had random starting problems with the motor recently and I had it towed into the marina 2-3 times. It would run fine I would take it back out and then just randomly not start. There was water in the gas from a gas cap not sealing properly at one point last year. We drained the tank and reinstalled. The marina is saying there is unbalanced compression in the cylinders 110-90-80 now and they are 80% sure that the problem is bad compression. They are saying in 2000 Mercury used a foam core head and it cannot be repaired, only replaced? Does this make sense? Are there any other procedures to check or other options before I make a decision? Spending $3500 on buying a head and repairing a motor on a pontoon that is only worth $4-$5000 seems crazy.
