Hey Guys,
I am trying to remove the flywheel on 1987 Evinrude 150. I have the nut removed. I started out with grade 5 bolts and stretched one into. Grade 5 is all I could get at 7 PM. I got grade 8 bolts the next day and pulled one of them into. Got anothe set of grade 8 bolts. The puller has been on the motor now for several hours with all the force my air gun will apply (whis is enough to pull a grade 8 bolt apart) and it will not come loose. I tried pinging the puller bolt and prying one side and then the other, pry on two oppisite side at same time.
Any ideas?
Thanks Larry
Any ideas?
Thanks Larry
