paislynmontgomery
- Jun 22, 2012
- 5
ok i bought a 1977 galaxy 19.5 ft bowrider very nice boat ford 302 175hp omc stringer outdrive everything worked great when i went to look at it and the next day when i put it on the water everything stayed great until i put it on the trailer to come back home and could not raise the foot up the tilt motor sounds like it is spinning free making no contact to the worm gear almost like a starter on a car when the bendix gear doesnt come out and make contact with fly wheel i pulled the worm gear cover off to manually pick the foot up to get it home i did drain the clutch cover and inspect worm gear and clutch they look good not worn looking but had water in the clutch cover instead of oil dont think that is my issue though since the tilt motor sounds like it is spinning free and making no contact any thoughts?
