Re: Advice upon installing Perko Dual Battery switch
Before you buy anything you need to understand WHY exactly you feel you need a dual battery switch, two batteries, and why you feel only one of them should power accessories. The fact is many boats simply don't need two batteries. The usual answer for having two is that if the start battery goes dead I'm dead in the water. No you are not. A simple jump start box will work nicely. If you have a killer stereo system then yes -- you maybe need a dual battery sysetem. Unless you have a high current draw accessory load you just don't need it. Now then, next you need to understand what the switch does for you. I won't explain that again since if you scan this list of topics there is an answer to your identical question. Wiring it any way other than as the switch manufacturer intended (everything goes to the COM terminal, you limit the usefulness of the switch.
