I have a 2007 60HP Bigfoot EFI on a 24' suntracker pontoon with 25 to 30 hours on it. Late last year I had 1 or 2 times when my keyswitch would not turn. This year I put my boat in and it started right up with no problems, drove the boat to the dock without issue. When I went to start it up again the key wouldn't turn. I ordered a new keyswitch went to install and the harness was not the same. After many hours and talking to a few boat mechanics they gave me a new keyswitch and told me to solder the wires. No problem, clean connections. Wouldn't start. Found a fuse in the fuse holder assembly number 3 which was blown. There was a 15 amp and I replaced with a 20amp. Nothing. I searched online and found a technician guide and it said if that fuse is blown it is a very good possibility the suppression diode is bad. I replaced and still nothing. I am not getting any power to my trim or gauges. Or the keyswitch from what I can tell.
Also, I should note, this is a pacemaker model so the serial number is throwing all of the techs off.
serial number 1C051638P
Any ideas where to start next???
Keith
Keith
