Fellas,
I've read through many posts and can't quite seem to find an answer, so I started this post.
I'm running a 1979 Seahorse outboard, which until recently, ran great. After zooming along the river for about 5 miles, the engine bogged down as if there were no spark until it shut off. Then, wouldn't start. Upon paddling 2 miles and getting a tow from a nice river boat the remaining 3, the engine started fine.
I towed it home to begin troubleshooting, and have not been able to get it to start since.
In my troubleshooting I disconnected the battery and tested the ignition switch. Although the push-to-choke feature doesn't work on the switch anymore, the switch successfully contacts between starter and 12V and disconnects the kill wire (black/yellow) from ground while in the on position, also, it successfully contacts the kill wire back to ground when in off position.
After that series of checks, I removed the cowl and located the powerpack. The two lead cables running to each spark coil are intact. Each spark plug wire is also intact. I tested and found continuity between each of these leads from the powerpack to ground (?). I disconnected the 5-pin connector between the ignition switch and the powerpack and still continuity between the spark leads and ground.
Here's the kicker, I checked continuity between the black/yellow kill wire at the powerpack and it is connected to ground??? I'm assuming this is incorrect and means there is a short somewhere either in the powerpack or on another ignition component.
My question, if this is indeed incorrect (blk/yel wire should not be grounded at the powerpack) then what would be my next step in troubleshooting? Since this is the blk/yel lead coming off the powerpack is it the powerpack that is shot? Could there be another cause I could troubleshoot without removing the flywheel?
I do have a Johnson-related Clymer service manual but not the OMC service manual. The Clymer is a general guide that explains a lot, but does not have my particular symptom listed.
Any direction is greatly appreciated!
Best,
John
Best,
John
