I'm chasing down an RPM issue with a fresh rebuild 454 mag EFI in a Baja 272. I've just eliminated the manual fuel pump and the VST and replaced with an external Aeromotive electric fuel pump, adjustable regulator and all new plumbing. My first question is, what do you do with the factory fuel regulator at the end of the fuel rail? Do you leave it in place? I am regulating the fuel on the return side of the fuel rail and returning the fuel back to the tank.
Second question and a little more history; I purchased the boat with a spun bearing so I did not hear the boat running before hand. A complete rebuild was done with some modifications. Cam, H-beam rods, Scat crank, .60 over (due to water laying in one cylinder) .100 dome pistons and everything ballanced. After rebuild it labors around 3k rpm's and tops out at around 3500. I had the ecm reprogrammed to match the modifications but still little to no improvements. Timing set at 8 degrees using a timing tool. I have a constant fuel pressure now of 43 psi. I just sent the injectors out to be reconditioned by Bill Johnson at Mr Injector. (Very nice guy and reasonable) He stated that the injectors were not off enough to create that much of a loss so I can rule out the injectors. The engine idles great and runs good up to 3k rpm's. I'm at my wits end:facepalm: and almost at the point to scrap the EFI and bolt on a carb. Any help would be greatly appreciated at this point.
