Re: Max Prop Diameter for Alpha One
1) Performance issue you are trying to correct: Trying to get WOT rpm within 4200-4600 range.
2) Current prop manufacturer, model, aluminum or stainless as a minimum: Quicksilver SS QS5052X (same performance noticed as with Aluminum QA2012X)
3) Current prop diameter and pitch (required). 14.5"D x 17"P
4) Wide open throttle RPM and speed with an average load (very helpful): 4100rpm @ 35mph
5) Engine/drive make, model, year, and HP: 1991 Merc 5.7 Alpha One (Gen I)...hp is 260, but I believe it was rated at flywheel in that year.
6) Boat make model, year, length and weight: 1991 Regal Ambassador 233XL (23 foot midcabin), approx 5000lb with gear.
Basically, the 17P is at the very bottom of the range (actually 100 rpm too low), and when I went to 15P (SS p/n QS5050X), it easily over-reved to 4700rpm (I didn't hold it there too long). That's why I wanted to try a 16P. It looks like they don't make a 16P 3-blade in SS, so I was thinking of the Aluminum 16D x 16P.
Not sure why the 16P's diameter is so big, though...??
