I have a set of 2003 mercruiser 350 MPI with serial numbers 0M317080 and 0M317081. They both have the motorola ECM 555's. I purchased a Rinda scan tool with the 4 pin connector. Went to check the engines out (no issues just wanted to see the info in the ECM) and when I plug in the connector, I get nothing on the display. I am almost sure that I need 12 VDC on the two outer pins that the scan tool hooks up to so I checked with my multimeter and am only getting 5 VDC. Both engines are the same. Any idea why I am not getting the proper voltage. The engines work fine with no issues. Any help would be appriciated. Steve
