fireman57
- Aug 24, 2004
- 3,811
Carbs have been totally rebuilt, new fuel lines on engine and tanks. Will get up on plane and then start loping. Gets worse the longer it runs. Pumping the primer bulb keeps it running right. Put new fuel pump on and still does the same thing. If you putt around at idle it will still want to die unless you bump the key so it is running lean at all ranges. Even tried another known good tank and line. At wit's end. Any help would be appreciated.
