I got this a couple years ago. It ran great the first few times out. We got to Canada & it seemed to start missing. At first, it was random, then it got worse. I changed out the plugs, even though they appeared fine.
I noted that the pressurized gas tank was leaking a bit at the top rim where you put the gas in it. Little tiny pin holes that kinda foamed up with gas. I sealed that up & it appeared to fix that issue. I was thinking that possible WATER got into the tank OR that the leak was causing the gas to not get to the engine properly DUE to lack of pressure inside the tank.
EIther way, still have the issue. I'm changing out the gas now. Not sure if there is anther item that would make it run rough like this. It is odd, one second it runs great, then it just starts running on one cylinder & then back again. Like there is a lose wire. CHecked wires that I can see, and all appears solid.
Any help would be great. Thanks, Kevin
