Re: question on ways of cleaning up grudge inside of motor
no no guys i rebuilt mine, where i was rebuilding my motor the owner rents out a spot for another mechanic he buys and sells construction equipment bulldozer back hoes and so on. he was just telling me how he adds trany fluid to the motor oil to clean out the sludge from motors and he also adds to freshly rebuilt motors to break them in , i told him i never heard of this before and i was just wondering if any other mechanic heard of this
Howdy,
The only thing that causes "sludge" in an engine is NOT changing the oil on a regular basis!
Adding ANY solvent (or any snake-oil for that matter) to the crankcase oil in an engine that has NOT had regular oil changes will risk engine destruction.
"Stuff" that breaks loose from oil passages on the "clean-side" of the oil filter can possibly clog the passage further up the line.
If it happens to an oil passage to a main or rod bearing, you run the risk of seizing that bearing and "spinning" it!
Spun bearings will cause all sorts of internal destruction!
The ONLY way to safely clean up the "grudge", is to dissemble, clean the engine and reassemble.
Tell your friends not to buy anything from that guy!!!
Cheers,
Rick
