martinthezman
- Jun 20, 2012
- 3
Hello, I recently received a 65 Evinrude Sportwin 9.5. I rebuilt the Carb and replaced the head gasket. The water pump housing was shot, so i ordered a whole new water pump [$110]. While installing, I removed the bearing housing seal from the bearing housing [which sits under the water pump], in my water pump rebuild kit there are two seals that resemble the one removed from the bearing housing. One is slightly larger than the other. I put the smaller seal in the housing, and only had to tap it lightly with a rubber hammer. But the larger seal looks more like the original one, but It will not go into the bearing housing. It is just a hair rounder than the hole.
Well, I took the motor out over the weekend for a spin, the water pump did GOOD. The motor ran OK. But yesterday I dropped the lower unit to adjust the shift linkage and I notice gear oil on my water pump. I checked the oil in the gear case, and there was some signs of water.
So now I'm thinking the larger seal may be the right one? Why are there two seals in this kit? Does the bearing housing have to be heated to insert the new seal? Any ADVICE?
