countryboy26047
- May 25, 2012
- 303
Ok, so I've read countless threads in regards to the merc 850's, but haven't found any with issues like i have..
I acquired my 1975 merc 850 about 6 weeks ago. From the beginning I've experienced the fun task of cold starts which seems to be normal with these.. now onto the actual problem.. I've also been having an issue where it'll run great once warmed up, throughout the rpm range.. I do have to back it off from 3/4-WOT slowly or it will die, but my biggest issue is, for example yesterday, on the boat for about 3hrs., 20min WOT, trolled at 700rpm for about an hour, then 1/2-3/4 throttle for another 45min., pull in to the launch, let her idle for a couple minutes and then shut it down.. 5 min. Later i have the trailer in, get in the boat and have to choke the crap out of it to start, then it won't stay running anything below about 2k rpm.
This has happened every time I've had it out, and also when I raise the motor I get about 3/4 quart of fuel dump from bottom carb into the case. I just put new NGK buhw plugs in it yesterday before our trip, and actually it cold-started without even touching the choke and idled right away, but then that problem when we got back in..
I'm thinking maybe a bad float? I've done a lot of engine work on 4-strokes, but this is my first 2-stroke..
One other thing, once the engine is shut down for 1-2min, the primer bulb takes about 1 1/2 - 2 pumps to tighten back up.. sorry this is so long, but trying to give all the details.. thanks in advance for any help here..
