Hi, My 6hp envinrude started missfiring..
i changed Plugs.. same issue.
carb clean same issue
model CE6SLCDE.
I was told to replace the coils...not sure wich ones?
I see this model has a Power pack, 2 Ignition Coils and I think a Coil under the Flywheel..
Any tips? If I have to remove flywheel I have no Puller, Do I use a Strap? how do I re-align Flywheel After?
Thanks any help appreciated
model CE6SLCDE.
