Johnson engine alarm
Bigkat650
Re: Johnson engine alarm
Typically its a sign of over heating. Check/replace impeller would be the first thing to do.
Bigkat650
Thankyou and the impeller is in the lower unit hard to remove?
Yes, typically the impeller is in the lower unit, and no--typically its pretty easy to remove/fix as it is a very common part that needs common servicing on all outboard, so they make it relatively easy to work on... but does depend on the motor.
Chris1956
It also could be another alarm. Why not answer Joe's question....
Chris1956
Ok, so it could be fuel restriction, or overheat alarms. Can you test it to see which one it is? If overheat it could be thermostats, waterpump or a combination. When was last time waterpump was rebuilt? If fuel restriction alarm, it could be tank vent or anti-siphon valve, or maybe fuel filter (main strainer or aftermarket filter).
Joe Reeves
225 ocean runner Johnson outboard 1995 maybe fuel restriction I don't seem to think so it still continues after slowing down
If the fuel primer bulb has a tendency to go flat, it's definitely a fuel restriction.
Which of the following alarms are you receiving?
(VRO Horn Warnings)
(J. Reeves)
NOTE: I retired around 1991/92. Possibly some of the later V4 engines and others may also incorporate a fuel vacuum switch that would enable a fuel restriction warning to sound as mentioned below, an unknown factor to myself.
1 - A steady constant beep = Overheating - The V/6 engines, possibly some others, have a fuel restriction warning which is also a steady constant beep.
2 - A beep every 20 or 40 seconds = oil level has dropped to 1/4 tank. (Late model engine = Every 40 seconds)
3 - A beep every other second = VRO failure, air leak in oil line, oil restriction, (anything that would result in a lack of oil being supplied to the engine).
NOTE - If the warning horn is the black plastic (overpriced) three wire type horn, the warning horn should beep once when the ignition key is turned to the ON position. If it does not, it is either faulty or someone has disconnected it (a stupid move!). At any rate, if it does not beep which indicates that the horn is non functional, find out why and do not run the engine until the problem is corrected.
