Hello all,
Purchased an 88 Doral Spriit this spring. Afte changing the starter and the lower shift cable I had it in the water for the first time this weekend, WHAT A BLAST!!
Anyway, once it was back on the trailer we noticed that I had quite a bit of water in the hull.
I hooked up the muffs and ran it, noticed that I had water coming out of the the exaust (attached picture) not sure if that is the correct place.
Took off the rubber hose and cleaned it up, had a lot of corrision/crap under the rubber hose. Going to reinstall and test it.
Question is should I put some silicone or something in there before I reinstall or should it be good to go as is? Also there wasn't alot of water coming out when hooked up to the muffs. Would this be due the the low RPMs? Would more water come out during normal cruising speeds?
thanks
Aaron
thanks
Aaron
