broncojeff78
- May 31, 2012
- 61
Hi there, this is my first time posting but have been lurking for a few months since i got my first boat. I have a 1964 MFG Niagara with a 40hp Johnson electric shift. The boat has not seen water since 2000 and likely the motor hasnt ran since then either. I bought a new water pump impeller, carb kit, points kit, and coils along with some fuel line to get her going again. I wanted to see if it would run at all so I cleaned the fuel lines out with fresh gas and squirted some gas in the carb and it fired right up. I had it in a garbage can full of water but didnt see any water coming out while running. I had enough water in there to submerge the water intake. After a few minutes of idling the high temp light came on and I shut it down. I thought I had heard that the high temp sensor was a one time deal that melted together to make the connection then it was junk? Not really certain where this sensor even is. Any suggestions as to other parts I should replace/check before putting this boat in the water? Thanks in advance for the help.
