Hi,
I just bought a boat with Chrysler 35 HP outboard
Chrysler 35 HP
350H8L 1978
S No 1119
50:1 fuel mix
It was not used last year by the last owner.
I could not keep it going, it would run for a few second then would give a "put" and stall, it might do this 2-3 times then refuse to start, only taking out the plugs (wet with fuel oil) and letting it vent/dry would allow me another try.
I put new plugs (set at .030) and caps on cleaned out the carburettor (set the idle to one turn out, it was set at 1.5 turns out as found) & I cleaned and set the points to .020.
It appears to run well now starts first pull but it does make a lot of smoke, I know its 2-stroke and an old timer but is it normal?
Here is a video of it running: http://youtu.be/C5aDTP8RGHc
Chrysler 35 HP
350H8L 1978
S No 1119
50:1 fuel mix
