Mercruiser 228 heating up?
4timesthefun
Engine has new t-stat and lower and upper water pump assy in outdrive. I have not had the boat in the water yet. Just on the hose. Just tuned and set timeing...engine idles well and no water in oil. Issue: On the hose, at idle and up to 1700 rpm's, engine will heat up, like t-stat isn't opening. If I take the t-stat out, engine runs cool to the touch, but will not warm up? Any ideas?
Re: Mercruiser 228 heating up?
Ayuh,... Welcome Aboard,.... Water that get's In, is gotta be able to get Out,...
Find yer blockage....
achris
More fish than mountain goat
Like Bond-o said.... Check your exhaust elbows and manifolds.... (and check the thermostat in a pan of hot water and a thermometer)....
4timesthefun
I did the t-stat test (160 degree stat). Honestly, it seemed to start opening hot, so i went to the auto part store and picked up a balanced (160 degree stat) and the engine did the same thing, started to heat up after about 5 minutes. So, i cut the guts out of the old t-stat and ran the engine for a good 30 minutes with the temp gauge in the green. Are you suggesting there is a blockage, not allowing the water out? If that were the case, wouldn't it also heat up without the t-stat because that's not the case? I know the manifolds/ risers are not cracked and are not leaking, but i have not checked them for blockages and will do so. I appreciate your input guys:)
patflemming
Did you solve this problem and if so how did you do? It seems I got the same issue with my 305 mercruiser 230. The motor runs hot but only with the t-stat. I have checked and dubble checked the t-stat and replaced with a brand new mercruiser 140f t-stat. Still the problem remains. If I remove the t-stat the motor is cold to the touch. Could it be flow check ball springs? Could it be the impeller not shovling enough water? Manifolds or risers?
