1984 weep hole leak
noturboat
I have a 1984 johnson seahorse 6hp i have what to me appears to be un burnt fuel . what can i do to slow that down. I have not been on the water in 2 days , and it still runs out of the 1/8 inch weep holes what do i do.
Rick.
Re: 1984 weep hole leak
It is perfectly normal and to be expected. It is unburned oil. It will subside in time. If you remember you can spend the last ten minutes of your day at full throttle and it will purge a fair amount of it but I normally forget to do it myself. Best of luck. Rick.
