Mercruiser 120 I/O back firing
87Relick
:confused:Can anyone help me.I have a 2.5L 120HP mercruiser engine that constantly backfires only under load.
it doesnt matter if i'm starting off or if I'm cruising and it just backfires.What could be the problem.
Wave thumper
Re: Mercruiser 120 I/O back firing
It could be a timing issue, my 5.0 with electronic ignition had a similar problem and the timing was out. Easily fixed with timing reset.:D
If the ignition system is a points style (sorry I don't know about your particular boat) and the points are bad, that can also cause the backfire.
