is my engine too low?
johnny howe
i have a 16ft 95 hp larson all american. it only goes 27 mph. does the motor look trimed right? too low? water does spray up and out from the cavation plate.
cr2k
Re: is my engine too low?
Looks right to me. The 3rd picture is diff. Maybe you are water logged? 27 is probably close depending on how much you are loaded.
coolbri70
i have a similar boat i had to replace the transom, stringers, foam, and floor. my motor seems to be at the same height, i have been asking the same question curious as mine is 18' and im in the mid 30s with 85 horses, maybe you have wet foam, i did
Texasmark
No. Looks ok to me too. Could be higher by roughly an inch, but certainly not too low.
Mark
scoutabout
+1 on the height. Certainly nothing seriously out of whack. Here's mine.
Couple other questions:
Is this a new condition or has it been this way for awhile?
I love that motor but wonder, are you getting all the ponies out of her. Also maybe the prop might be a place to investigate? What's your WOT rpm and is it within spec?
That does look like a solidly built boat. If it is waterlogged that is going to add lots of weight.
FWIW, my 90 hp on a (relatively light) 17 footer is good for about 40 mph solo with a near full tank.
johnny howe
about 27 on speedo, my tach quit working, this is wide open throttle. i do think my engine can turn more rpms by the sound of it. but my throttle is all the way forward without any more travel.
http://youtu.be/We46AmroEcQ
