Re: 1983 bayliner capri AQ125b wont start
I have a 1983 Bayliner Capri..volvo AQ125b 4.0 liter. Have replaced starter, coil, coil wire, points, rotor, distibutor cap, plugs and wires..I have spark at the points but not at the plugs, cranks but wont start. Any ideas
Is that really the points sparking? I do not think it should be! I would replace the cap again.
Obviously something failed from all those new components when your engine stopped.
Do you get a spark at the coil, before the distributor?
If not, there is not much there to go wrong. Again, start replacing components one by one. (Hopefully you still have your old components, it is highly unlikely that all of them was bad, or you have spares.)
Do you get full power (12V) at the coil? If there is a ballast resistor then you should get about 9V at the coil when the points are closed.
If you get spark at the coil, follow it to the plug. You should have about 3/8" of spark in free air.
Good luck, Peter
