oil leak from mercruiser alpha 1 out drive
Don S
Re: oil leak from mercruiser alpha 1 out drive
Remove the drive, Drain the gear lube, pressure check the drive and listen for the leak. You may be able to see it by spraying soapy water in the front of the drive where the water pump and vertical shaft are.
