grey hose on trim and tilt
TexasIvey
I have a mercruiser alpha 1 3.0L. I have replaced both the gray and the black hose from the pump to the distribution block. I dont remember where the gray and black connect on the pump. does the grey go on the left port as i am stand in the boat looking at the stern?
Don S
Re: grey hose on trim and tilt
Which pump do you have?
Ayuh,... Hook 'em up, 'n Try it....
If it works backwards, Swap 'em....
