So we just picked up our first boat on Memorial Day weekend. Got it in the water the next weekend, Sat, everything was great, not a single issue. Sun all day was great and smooth, then when into a small cove, came out and took a lap around the small lake, on the way back to the ramp, started to hear a knocking noise, shifted back to neutral and the motor shut off. Looked at temps, they were at 240 or so. Never got it restarted. Took it to the shop, they replaced the water impeller, though it didn't look bad, and the housing as it had melted. I think debris from the cove blocked the water intake. They also changed the oil, as we wanted to make sure the previous owner used the right type. After service, we get the boat back in the water, go out to our little sitting spot... everything seemed normal again, then back to the marina to pick up some friends, no problems. After we picked up the passengers, and were headed back out, the knocking noise came back. There is no sound at idle. And I can't get it to reproduce the noise while on the hose. It only happens above 2000 rpm, and only while in gear and moving in the water. Originally the techs thought it might be the exhaust flappers, but we checked those, and they still seem covered in rubber, and don't think they could make this sound. We got a tech to listen to it in the water, and he thinks maybe a loose rocker, or bent push rod. Just thought I would ask the opinion of other experts before we started tearing it apart.
http://www.youtube.com/watch?v=HRyOwnhQwgE
Thanks for your help
