Grady-white deck drain
Bluefish
Hi hope you can help me I have a 204C overnighter 1991 the deck drain fitting broke located just forward of the port seat box in the cockpit area. I was hoping you can tell me how to gain access to it I believe if the center access cover is removed about 18?X14? there will be a stringer in the way, I see in on the bottom of the seat box there is a pieces of wood held in by one screw if removed will this give me access I cannot get my arm in and down at the round 4? access cover behind the fish well. Any help would be appreciated
dingbat
Re: Grady-white deck drain
I replaced every fitting on mine (1987) when I owned it. You can access the starboard side from inside the cuddy. You may be able to reach the port side as well
Bluefish
Thank you for taking the time and replying I agree with you on the starboard side, didn’t think about going that way on port side will try to take a look at it today
