U-Joint Grease
FreeBeeTony
I just got finished doing maintainance on my outdrive......water pump, seals, new gear lube, etc.....<br />I greased the u-joints......the grease in the gun was "trailer wheel bearing grease"....<br /><br />Is this grease acceptable? Is there a special grease recommended?
KRS
Banned
Re: U-Joint Grease
I know it's an answer you weren't looking for, but what does the service manual call for?
trog100
Re: U-Joint Grease
"Is there a special grease recommended"<br /><br />there is always a special grease recommended aint there.. he he.. the interesting question is just what happens if u dont always follow these special recommendations..<br /><br />guilty your honour.. <br /><br />trog
Don S
Re: U-Joint Grease
Merc has out a grease called by the odd name of "Ujoint and gimbal bearing lubricant"<br />The picture below is from their site.<br />The reason for it, is some of the grease types Mercruiser has, like spline grease and 24C, will cause the bearings to slide instead of rolling like they were designed. Which causes them to wear out quicker.<br />I would guess there are several greases out that works for bearings like the ujoints and gimbal bearings. I just don't know which ones they are and I do know that Merc has already done the research on which is best for them.<br /><br />
