Just starting out boating. Recently purchased a 14' aluminum tub. Came with a Yamaha 9.9HP electric start 4-stroke. In reading other posts since registering on this site I have discovered a potential answer to my problem. The boat will not get on plane...even with just me in the boat. I determined that it as a Long shaft engine mounted on a short shaft transom. 1)Should it get on plane with that small of an engine? 2)Should I look for a used short shaft engine or build a bracket to raise the mounting on the transom? I hate the idea of drilling holes in a boat. PLEASE HELP!!!! (BTW the transom is 15" high)
