Re: 4.3 GL engine block drain plugs.
It's probably just rusty. Do you leave the plugs out for winter?
Clean the threads and use some gasket sealer on the plug (NOT teflon tape) the sealer will prevent future rust. Also, put the plugs back in after draining, then the threads won't get all rusty.
